After you get the "non-supported" error, please save a trace file and send it to me at [email protected]. Include a note saying why you are sending the trace file.
All DMA PIDs were renamed from *_DMA to *_M.
When you load in a BBL file contining the *_M names, EFILive converts the PID names to *_DMA so that the Scan Tool software can understand them.
I still don't know why your FlashSCan is saying AFRATIO_M is unsupported.
Have you sent me the trace file yet?
It is possibly a permissions restriction in Vista.
Using windows explorer, locate the file:
C:\Program Files\EFILive\V8\EFILive_Explorer.ini
or in versions prior to the May 12 update:
C:\Program Files\EFILive\V8\EFILive_Hapi\EFILive_Explorer.ini
Right click the file and select properties.
Select the Security tab page.
Click [Edit] button.
Select the "Users" item.
Check the "Full control" checkbox.
Click [Ok].
Click [Ok].
You may also need to do that to EFILive_Hapi.ini file (in the same folde) as well.
Thanks Paul. That took care of it. I had made those changes, but not for my username. I hate Vista...
