Originally Posted by
hymey
I do the same as Simon, sometimes I flash e38's and they do not clear codes when they should so I manually clear them.
Latest issue, Turning cat protection enable to off does not seam to work on some os. The DTC is activated still on long drives, so I leave them enabled and raise the temp enable to 2000 degrees C.
Some weird things happen with e38s and reseting the ecm is the go. If the ecm has learned it self to idle at 8g/s and it needs to be 5 and you command 5g/s it will still try and idle at 8 etc.
Personally I have not had any LTFT issue's as I never use them, but it is a good idea to reset anyway.
Wait till you flash a car that has been tuned with HPT cos, even after a full reflash there are so many glitches!
