Thanks Eric, I think the serial number is embedded in the RR, so even the guts kit swap is going to have issues I think, I'm not done trying yet, let me try another person for help then I will let you know about the swap.
boy it sure is great taking 2+ hours just to adjust the TCC in my trans since I cant get my RR to work in my v6, I when there are known others who get this to work. ive sent Craig 4 or more emails with no response, must be he doesnt want to sell any RR's since I have even offered to buy another one, I dont even think he checks his e-mail, I only had 1 response right after he posted here, man this is really annoying!! :ranting:
Send him a PM.
It is not like him to not respond promptly to email,
he may not have gotten it or may not be able to.
Did you use the email form on his website? He usually responds to me on the first day. Maybe because your problem is complicated? I'd use the form on his website instead of his direct address.
I'm going to try to load the V6 tune in right now actually once I find it here. I guess in the name of us being tuning brothers, I'll eat my spare license swapping RR's for you if you would like if it takes the V6 file.
Dont try to waste an EFILIVE license, EFI live doesnt support the v6 files, only tunercat does. if we did swap RR units i believe we would have to contact paul or ross to have our licenses swapped. i am still trying to get mine to work, I just need to get ahold of Craig.
I just programmed your 2001 .cal file and it seemed to work fine except when I tried to read it the other software gave an error box saying the file has one or more incorrect checksums. That checksums may may be disabled or the file corrupt.
Now I programmed your 98 file. Again, seemed to work fine. Read it and same safety box.
My girlfriend has a 2002 V6 S10 and so does my dad. Lets figure out how I can test my RR on a live V6 for you on this end and then we will swap and I'll try to figure out why yours doesn't work.
I'm going to TC her V6 when she is sleeping tonight (LOL!). Can I program it into my 512k V8 RR and it will work or do I need a V6 PCM? I have a spare V6 PCM if this becomes necessary.
Let me know asap so I can go try this out.
Eric
if it is a v6 s10 it should be the 0411 pcm which I assume is what your RR is, mine is a 0411, the V6 car pcm is different, it is a 717. your RR should work just fine in a 2002 S10, but you would have to swap the guts out in to a 717 to make sure it totally works, then find a 2001 ish L67 3.8 717 equipped FWD car for testing.
IT WORKS!!!!!!!! I just have to give props to John from TC, I sent him an e-mail and I had a response within 12 hrs with the fix, I had an old version of the RR program was my problem. any time I have ever had a question he always responds way faster than anybody i have ever delt with. Thank you John :master:
Guys, on the V6 PCM, we started to add support for them some time back but the project never got completed. At that time the E38 & E67 ECM's just hit the streets and we thought that support for them was more important than spending another month or so on the V6 PCM.
2 years on unfortunately we just haven't had a chance to get back to the V6 PCM again.
On a positive note though, we were working on all PCM's from about 98 through to the last of the 3800's which I think is still used in one model using the P05 PCM.
One day we'll get there.
With Craig, I am sure he now has someone employed full time to handle support, check he's website to see if there is a support@ type Email address rather than trying to get him direct.
