I need to scan a car at the track. I just uploaded the E92 file and selected all my pids but when I scan I get a message like Mem pwr reqd.
Any idea's and has anyone used and autocal on a C7 yet?
I just went out and checked again the actual message is below
ECM
REQ PWR_M
That pid is probably not supported by that ecm. Try removing that pids from your list and try again.
Whenever you start logging and the AutoCal displays a message with two lines:
Line 1: Controller type
Line 2: PID name
In your case:
ECM
REQPWR_M
That means the PID REQPWR_M is not valid for that ECM. Remove that PID and retry data logging.
PIDs that end with _M are defined by EFILive per operating system, so it may be that PID has not been configured for the operating system in your E92. What is the operating system in your E92? I'll check to see if/when support for it will be available.
Paul,
I will go back and look at all the pids. I don't have my laptop in front of me but I will respond later tonight with OS. I have not been playing with the C7 much but now I am ready to get rolling quick. What do you need from us on the E92. Just email or message me that.
Justin
Zip
Removed the torque pid and it works.
I don't remember if I sent you anything. I would still like that pid. However I have a new issue on a different C7.
We are trying to log one at the track and I can't log E92 and T43 at the same time, is there a way to do this. I need to be able to log "current gear" along with everything else. Also I would like to log the odometer if possible so I can see in feet where the car is shifting.
Justin
