1 Attachment(s)
Cummins .calz update - v7.07
Here's a small update for the .calz files for the 5.9L.
Added:
B9904 "Main Injection Pulse Limiter Option" - Used to enable or disable the Main Injection Pulse duration limiter. With this set to Disable the main pulse time will not be altered in any way from that commanded in the pulse time table.
B9905 "Brake Torque Management Option" - Use this to disable the power limiting when loading up whilst stationary. If set to disable this will still retain a functional PRND display, reverse lights and no start in gear.
Regarding B9905, heed this warning: It is not recommended this be disabled on a stock truck, driveline damage will probably result.
Download and extract THIS ZIP file in to the folder to match the Windows version you have:
C:\Program Files\EFILive\V7.5\Calibrations\CMB (for 32bit Windows versions)
C:\Program Files (x86)\EFILive\V7.5\Calibrations\CMB (for 64bit Windows versions)
There is no need to update your software or firmware to use these files, though we would always recommend you are using the latest versions anyway.
We are releasing this as a zip file update because unfortunately our auto software updater is causing a lot of troubles so we are looking for a new one to replace it.
Have fun!
