Its seems that many tuners adjust the tail end of the MAF {B5001} table and I am trying to undertand when that table should be tweaked. Is it true that the MAF typically doesn't get touched from stock calibration if the intake system on the inlet side is not touched??
This also leads into the question of WOT fueling; can both the {B5001} and {B3618} be used togther?
Howard
