Hi i'm trying to adjust my railpressure with efi dvt but when i hit active button the car just shuts off, same happens when i try to adjust idle.
Is there step by step instructions how to do it?
We will check the configuration for the DVT's on the LB7, but I don't recall anyone having issues like this. The only thing I can think of is when the DVT is activated the value in the slider control is too low?
Yes i think the values are too small the slider gives only 1 and below for the values and it doesnt work,
if i change the value manually to something suitable same thing happens engine shuts off.
We checked the configuration yesterday and it looks correct, it 'should' be working ok. This is the first time we've heard of the two controls you are trying to use not working, but, unfortunately we don't have an LB7 to physically test this on, so the only option at this point is if someone else with an LB7 can try as well to see if the problem occurs for them too.
hello!
I have an exact problem, if I try adjust rail press , if I use slider nothing happens, same thing with the idle speed
Hi!
any update on this problem? could this be keyboard related, i´m using European setup?
After trying to adjust the rail pressure using the DVT controls, stop the data logging/monitoring and save a trace file using the menu option: File->Generate error report.
Then send that file to me at paul@efilive.com
Please include a link to this thread so I know what it is for.
If I get a chance this weekend I will test this on my LB7 to see if I have the same issue.
Did you activate the DVT controls and the fuel rail pressure as shown in the image?
Attachment 13440
