Swapping 12200411 PCM into 98 Chevy Truck
I want to swap a 12200411 from a 01 or 02 Chevy Express van (which is supported by EFILive) into my 98 Chevy truck (which is not supported to my knowledge) obviously so that I can tune my truck myself and will be able to use the custom OS for 2 bar SD operation. For reference the 12200411 PCM uses OS 12208322 and can be converted to the cooresponding custom OS 01270001 I believe.
I have a few of questions about the swap and EFI Live in general:
1. Will I be able to put the vin from my 98 into the 01 pcm so that it will read the correct vin when I go to smog my truck?
2. I would like to have a spare PCM handy in case something fries, and eventually will build a bench harness for testing purposes. Does each PCM require it's own license, or will it only require one if it's going into the same vehicle?
3. Does EFI Live require that you use a licence to scan and save a file? To do a full reflash of a PCM?
4. Is the 2 step rev limiter implemented in the 01270001 OS?
I'm a real noobie to this and haven't purchased yet, so I hope I'm explaining this correctly. If I can't pull this off, it probably won't make much sense for me to buy it, so any insight is appreciated! Thanks! :)
