F302 Green Top Injector Specs
I've been meaning to post this information up here for a while. I was messing with the B3701 table from stock and noticed a big improvement in drivability. I wanted to know what the real specs are on these injectors so I called Ford and they came through big time. Here's the info...
Ford SVO Green Top 42 lb Fuel Injectors
Ford Part # M-9593-F302
Bosch Part # XL3V-A9A and 280150558
All from Ford Tech Support (800) FORD788, 1-800-367-3788
Q: What fuel pressure are the injectors rated at?
42 lb @ 39.15 psi
Q: What is the Injector Pulse Width Voltage Adjustment?
They called this "Injector Offset"
V - ms
6 - 4.986 ms
8 - 2.098
10 - 1.321
11 - 1.095
12 - .919
13 - .786
14 - .670
15 - .575
Q: What is the Minimum Pulse Width for the new injector? Stock LS1 is 1.27 ms.
1.13 ms
Happy tuning!
Dan
