Is there any way I can reset or do something to drag my tunes to the BBL? This happened all of a sudden and I'm totally clueless. Please speak plain english as I'm not a computer wiz or an engineer. =)
you and me both.
What version of V8 are you guys running?
The latest and greatest.
With the previous version it worked great.When I updated to the latest on both of them,neither laptop will drag them to explorer.
No error codes either
Thanks Erik
Have you tried uninstalling the V8 software completely and reinstalling fresh? If you do try this just take copies your 'C:\Program Files\V8' and 'My Documents\EFILive\V8' folders before uninstalling and delete them before reinstalling, that will ensure clean files will be created. I'm not hearing any major issues from other customers (which I would expect to) so I' assuming for the moment it must be customer specific.
I think so also.I did uninstall and reinstall,i will do what you said and email you.
Noticed that as well , just did copy>paste and it worked , just thought maybe they took the drag-n-drop out .
Latest version .
Boy do I feel like an idiot.LOL I have been trying to drag them like I always have,didnt even think about copy and paste:wallbash:
The .tun or .ctd file in EE to the V2 .
In EE once the V2 is plugged in the software allows you to move files from the upper section (Program Files>EFILive>7.5>Bins) to the lower , the lower (Tuning tab selected) being the V2 memory that is used to Black Box Flash the PCM .
I can't make this problen happen...?
If I try and drag-n-drop a file I get a circle with a slash through it and file will not transfer , but if I do copy-n-paste works , and if a file with the same name is there it asks if I want to overwrite or not (which it should) .
But no drag-n-drop !
Build 133 ST-n-TT , S-n-T Build 115 , (don't have unit next to me) firmware is what corresponds to build numbers .
