csp 5 pass thru switch W/ cts2 monitor
I just recently tuned a truck with csp5 tune and customer is saying that it feels like they loose there tunes once in awhile and eventually they come back. I wasn't sure if it was an issue with monitor being run through pass through switch or if switch may be faulty.
Thanks,
Daniel
Just had a truck today with a pass through csp and the cts2 won't power on when connected to the pass thru. Anyone experience this? Really wish an agreement could be made for the edge to at least display which tune is running, have another truck that will occasionally not switch tunes and requires unplugging the switch to get a response, again using edge to monitor.
I'm not sure if there is a solution for that, other than resetting it. I learned in the beginning that your issue is gonna happen when you have two devices trying to do the same thing on the same network.
I unplug my switch when logging then plug it back in when completed
