On the V2 interface there are 2 12 volt switch inputs. What are they used for? I thought I read something about them a while back but, can't seem to find the thread.
I thought they were 12V analog inputs which should read the voltage from 0-12V.
Ira
Just discrete inputs, the cannot measure between 0 and 12V (4.5V, 7.8V etc), however, they are handy for measuring relay states (on/off) or switches etc.
Ok, thanks Ross
So this might be used to log something like a nitrous solenoid to see when it turns on/off?
Hi, I'm wondering if it is bad on the flashscan to input 12 volts to one of the inputs to log actual nitrous activation from the solenoid. I know it won't read the voltage. I just want to use it more as an on-off way of logging the nitrous activation point. Thanks a lot!
I have a v1. I don't know if that makes any difference
you do not want to hook 12vdc to the V1 inputs. You would need to step the voltage down to a 0-5vdc range.
Now that I got bottle pressure, fuel pressure and WB logging, I want to use these these relay inputs to indicate stage one and stage two of my nitrous system firing... How do I wire them (I am in Singapore so I cannot look at the back of the unit to figure it out...)
Being we don't need the grounds on the plugs for the Fuel/nitrous/ and WB inputs, can I just take a hot feed (from my LED Stage Indicators Powered by Pin 87 on the relay) and put that to + on the V2 relay inputs and be off and rockin???
Playing around I was expecting to see it come up as a STATUS when selected as PID...but it does not, has anyone used this yet???
Easiest way to do this would probably be getting a Zener diode, e.g. 4.7V, and a resistor ...Quote:
Originally Posted by TAQuickness
Anyone help me out with my Questions?
Other option is set it to a 12V gauge and have it turn green in Alarm for indication?
Be nice if this was available as a status function (or is it and I am missing something).
No, its not availabel as a status.
It is available as a "guage" or "chart" pid that can take the value 0 or 1.
So for a status like effect, set the alarm to Green on the gauge, set 1 as the value for alarm, and when activated, set all the colors to black other than alarm.
Seems to me, the status function would be more suited for this application :bawl:
What about the wiring, + pin 87 to the V2 + and no ground needed because the V2 is grounded?
