Originally Posted by wait4me
You have to Do a relearn proceedure for the trans to act better, It is just a little more power than it is set up for on the trans? Hopefully GMPX will get the Allison controller cracked so we can play with those settings and be in control..
I forgot what i had to do to make the trans normal again.
Im not saying that this tune is going to be good for components, I was just putting it up there for people to see how simple adding such a large amount of power is.. :) 100 hp is alot of power added,
2 fueling tables is what made all the difference. you can see in the history tab of the .tun file of all the tables i changed. Thanks :)
