Known issues with June 02, 2015 Public Release
Currently known issues and possible workarounds for the June 02, 2015 Public Release of the EFILive Software and Firmware
Download the current/stable release software here: http://www.efilive.com/latest/cat/download-efilive
Download the public pre-release software here: https://forum.efilive.com/showthread...ic-Pre-Release
Public pre-release software versions
- Software: V7.5.7.285 (updated, see Issue #3 below)
- Software: V8.2.2.278 (updated, see Issue #2 below)
- FlashScan/AutoCal firmware: V2.07.84
Issue 1:
Workaround:
None.
It is a restriction of the *.efi (V7.5 log file format). That restriction will be removed and the TCM PIDs will display their true origin once the V8 scan tool software is available.
Issue 2:
Log files created with BBLogging or V7 pass-thru for CMD and CME controllers cannot be loaded into the V8 Scan Tool.
Workaround:
Download the updated public pre-release for V8 and re-install the updated version.
Download is available here: Download Updated V8 Software
Issue 3:
The latest CMD/CME CSP% calibrations were left out of the V7 install.
Workaround:
Download the updated public pre-release for V7.5 and re-install the updated version.
Download is available here: Download Updated V7.5 Software
And I cannot get a CMD-CSP5 log to do anything in V7.5 Scan.
By that I mean, PIDs are not shown as valid to a CMD controller. Pass-thru or opening a BBx log.
Edit: I can get a bbx log to open in v7.5 now. My mistake. Still need to select controller when opening.
