Bootloader rejected
very green to efi live, but was trying to switch tunes and while communicating with the truck, the laptop would tell me bootloader rejected, try again in 15 seconds and try to turn off high speed. A little lost at this point, any help would be great. The truck is a six speed manual LLY with a clutch and exhaust. Any help would be great thanks in advanced. Dan
Did you have the radio fuse in? or was the door opened, anything that could cause anything elctrical to turn on/off?
-Nemo
The fuse is in, and the only light that was on was the brake light on the dash.
When i load tunes I have to unplug my radio fuse, turn all lights off, my aftermarket amp unplugged, and somtimes I need to hook a battery charger up also.
-Nemo
Just thought about it, when i turn the ignition off i pull the key out and that will mess with the lights because its a manual truck. I'll try to just turn it off and not pull the key out. Thanks Nemo!
OK will try the fuse thing! Thanks again
Let us know what happens...
-Nemo
Pulled the fuse, never took the key out just turned it off and everything worked great! Thanks again Nemo!
Good deal, enjoy. ;)
-Nemo
Yes, the idea is to prevent other modules chattering on the serial bus during flashing.
On a stock truck this should not be necessary, it's when aftermarket audio devices are added that connect to the data bus when things turn bad.
During development we tested reading / writing on a dead stock LLY without any fuses needing to be pulled.
Oh, I see, the aftermarket radio is the offender.
my truck is all stock radio and no accessories on or plugged in and the first 10 times i tried to tune it was rejecting it due to the bootloader deal. I unplugged everything, shut the key off and gave it a few minutes, tried it again and it worked like a champ and has been working great ever since. Just a little fyi for those of you freaking out right now like i was reading thru all these threads.
