Hi,
I have camaro 98, I swapped both heads then both fans r on all the time. I know that there is no relation between the swap and the fan but it seems like the mechanics did a grounding problem. Any help??
I made some trials, like shutting them off by the DVT and it worked. And the samething happened with the AC.
