I looked around and didn't see anything on this.
When setting up the PID selection to load into my v2 the temps, speeds, ect are all metric.
How do I get imperial PIDs into the list to use?
1) Open up the V8 Scan and Tune software,
2) Click on BBL,
3) Select the PIDs you want logged on your controller,
4) Once you have all your PIDs selected you can right click on them and click properties,
5) You should see a 'custom' section,
6) Select the imperial unit you want the PID to be displayed and logged as
7) FYI: You can toggle between metric and custom by pressing 'enter' on your V2 unit
Good luck :cheers:
When I do that with mine, it won't allow me to change it to imperial...not sure what's going on. Anybody have any ideas? Haven't tried toggling on my V2 yet. Can someone paste a copy of the default LBZ pid descriptions on here so I can get them? I was messing with some stuff I shouldn't have, enough said lol. Thanks.
thanks! that worked wonders for me
I tried right clicking on them before I asked, but I was doing it before I added them to my list
Have the same issue with mine...doesn't give me any options in the drop down box for metric/imperial selection. Am I missing something?
Same thing going on for me. I have not tried it on the new build 58 till now. It did work for me for sure in build 55. Looks like a bug in build 88 maybe. Unless others have no issue in build 88.
Brian
I'm not sure but it looks like the V8 'Options.txt' file is not looking at the 'EFILive.ini' file for the alternate (Imperial) measurements. If they were in the 'Options.txt' file from an earlier version they are still there but nothing new can be added. I haven't tried loggng to see if the PIDs values show up in Imperial or Metric. Will give it a try when I get a chance.
Just hooked up V2 to car and PIDs in Imperial as they are in my 'Options.txt' file.
Yes my current options.txt file has some in Imperial and is fine there. Just adding new PIDs or even trying to change current PIDs back to Metric if Imperial or vice a versa no longer exist.
Brian
Well thought I give it a try and remove what I had to install the newest release off the site instead of the updating I did to get to build 58 from build 55. It did delete EFILive.ini during the uninstall. But on reinstall it still does allow a change of Imperial or Metric values for the PID.
Can I get a copy of the build 55 release or link to it and install that to see if it restores itself.
One funny thing is after I installed V8 build 58 it said there was and update. Well the install says build 58 and of course the update still ends up as build 58. No idea there. But still not changes to metric or imperial.
Got a few more things to check but looks like a bug that may not be calling the right Header in EFILive.ini file.
If anyone is still V8 build 55 or earlier please post your EFILIve.ini file for comparison.
Brian
Thanks Mr.Prick for posting that for me. I'm still lost about changing over to imperial with V8, my software doesn't have the option when I right click after dragging the PID over, any thoughts? Is it something in my options.txt file, what needs to be done there?
Just tested the latest update here and got the same problem. Will fix it asap - apologies for the bug.
No problem there Paul. Can't always be perfect. But just curious if one can access older EFILive software?
Brian
No we don't keep old versions on our server.
Meanwhile, you can simply enter the conversion factors for Imperial units in the PID Property window. The drop down list box is really only for convenience. Use the EFILive.ini file as a reference to see which factor/offsdet values you need to use for various conversions.
Has this been fixed? If so I missed the fix.
It doesn't look like it as the last update was prior to Paul's post. It probably got lost with BBL reading beta testing. Paul hinted that BBL reading was going well and an update should be available soon (day/week/month ?), hopefully all the fixes will be in it.
Yes, the fix for Custom PID units is in the BBR update.
Any idea when this will be available to use imperial units? It's tough for us guys in the states to understand metric sometimes.
Optimistically, I think the BBR update will be available publicly by the end of this week. That update has the Imperial units fix in it (along with many other fixes/updates).
any word yet on the update?:secret:
Imperial units are being displayed on BBL display...
you need to setup Custom Units for each pid using Scan&Tune->Black Box Settings.
The latest release candidate (RC2) went out last night to the beta testers.
I have not made that release publicly available yet.
Once I get some more feedback from the testers and if the feedback is good I will make it public.
so my old laptop burned up a motherboard, I got a new one running win7 and am trying to get things set up again...but now I can't just select imperial pids
I have no idea what half the posts after my last in this thread even mean to be honest...is there a fix for this yet? could I copy and paste the option and setting save files from my old computer to the new one if i pull the harddrive and put it in a usb case?
Make sure you plug your FlashScan into your car and computer then open the scan tool and validate the PIDs. Have you changed the unit display to Imperial from Metric?
ah I haven't plugged into the car yet, its late
it's been a long time since I've messed with efi live because of all the computer issues I was having before it died on me...
I thought last time I just right clicked on the PIDs and changed the custom display to imperial, but now in the custom drop menu there is only "NONE" instead of having "imperial"
I think I'm going to call it a night...it took me forever to get the drivers installed, apparently windows 7 really didn't want to add them automatically and it took me a bit to find how to manually add drivers from a folder as it wasn't a presented options...had to dig around in control panel to find it
this is the part I hate about a new laptop
Post screenshots.
http://img.photobucket.com/albums/v4...bblcapture.png
when i click the drop box it displays "none" in text and nothing else
Post your Options.txt file... is it the latest one that came with V8 build 75...?
the unit was purchased on nov 2008 but it did updates as soon as i installed it on the new pc
i might go ahead and uninstall and reinstall first just in case something went wrong, maybe that's why it wouldn't install drivers for the v2 as well
if that doesn't cure it, I will post my options.txt file
You can download/install the latest versions from here: showthread.php?p=105679#post105679
Build 75 had a bug that did not give you a choice there. Had to use a previous version or use the latest public beta versions of V7.5 and V8 for the fix.
Brian
Hello All,
I'm new to EFI Live. I have read and learned a lot. I have read two threads dedicated to changing some of the metric PID's to imperial units. I cannot tell if 8.1.2.84 is capable of it or not. I can get to the properties menu, but there is no pull down to change it. At this point I do not have the ability to edit the options.txt file.
Could I get a little guidance on this one
TIA,
S
Have a look at the attached pic... the pull down should work, it will contain the "alternate" units.
Thanks again joecar,
Wow do I feel dumb. I did not think to try that I read and worked at it for an hr. You must get real tired of answering the same questions over................
How do you keep track of it? If it is a file, it would be VERY useful as a guide for others.
S
Hah, don't feel dumb, software (not to mention tuning) is an 11 on a complexity scale of 1-to-10.
I have some screenshot images I saved, I was thinking of making a pic tutorial... see attached...
More...
joecar,
Those pics are an outstanding way to instruct setting up BBl. I found the first ones... and I figured out how to accomplish the last ones. I was missing that one that displayed the units config.
You should make those available for everyone to easily find. I'm beginning to learn a few things. MOST of the info is in the forums. There is a LOT to learn. some of it changes quickly. And figuring out how to make it easily available and administrate it seems like a monumental task.
Do you think "we" as a group will ever gather on terms to wiki this info into a GOOD beginner guide? I'm so strung out from learning, I have nothing to apply to learning how to create a wiki or other to help beginners. Hell, I still can't map a good flow chart in order to structure the publication.
S
