has anyone ever tried to use acetone in the fuel tanks and has anyone had any sucess?
No but I knew this tweaker dude back in the day,
that used paint thinner to run a generator. :bad:
I ran for a little while. :hihi:
http://www.pureenergysystems.com/new...00069_Acetone/ check this site out, supposedly it is supposed to have huge gains in m.p.g
March 17, 2005
"Not more than three oz. per 10 gallons."
It's kind of an old article, there surely is some follow up somewhere. :nixweiss:
must be. My main concern was the effects it would have to your engine? Supposedly its not good with plastic.
At this concentration the only probable benefit is the cleaning effect that the acetone would have on the fuel injectors. As far as the possible problems that the acetone could could cause, keep in mind that acetone is sold in plastic at Bunnings.
It would probably work well on an old gummed up set of injectors, just like the ones that the people on the 'hypermilers' forums seem to test the acetone on.
My preference is for the marine 2 stroke additive that is doing the rounds.
Just my 2 cents worth.
Cheers, Steve
I've tried it with limited success. I have friends that claim great MPG increases. The best I've seen that I could confirm from it was 10%. I thought it might help me to run mid- grade or regular in my vehicle that requires premium, but it didn't. It also doesn't seem to help with any fuel that has alcohol added to it.
ya i have tried this in many vechiles works good a inj. cleaner
have you ever heard of it damaging your injector seals? or any other seals for that matter?
This urban legend is making about its 12th trip around the internet. The idea that such tiny quantities of any aromatic would have any measurable effect on anything other than the ego of the purchaser is ridiculous. Somehow these "secret tricks" always escape the legions of PhD petrochemical engineers who do this kind of thing for a living.
tried inj. cleaner all brands acetone seem to work better on old cloged inj.
Acetone's main benefit is an increase in the knock rating of fuels like regular gas. With carb'd engines it does contribute to improved vaporisation if there are challenges there, though at high cost.
If tuning an engine for more timing can gain mpg, then it may decrease gas usage via the anit knock quality, but the cost of adding the acetone is generally higher than the mpg benefit gained.
With a stoic not that much different from E85, for improved anti knock easier to add E85 if you can get it. It's less than one tenth of the incremental cost.
Organic Compound ______________ Boiling Point, °C.
Acetone _____________________________56.5
Methanol ____________________________ 64.7
Ethyl acetate ________________________ 77.1
Ethyl alcohol (100%) __________________ 78.4
Ethyl alcohol (95%), the azeotrope ______ 78.1
Propyl alcohol ________________________ 97.2
Water ______________________________ 100.0
Butyl alcohol ________________________ 117.5
Amyl alcohol ________________________ 137.8
if you were to make Ethanol to run your car you would need to distill out other compounds that are not favorable. I grew up with 55 gal drums of Acetone around me. The stuff is a great cleaner and other the distorting/attaching plastics and rubber products it cleans metal. Squeaky clean metal will oxidize. Fuel lines will rust from the inside out. The rust gets in the injectors and damages them. I have seen pictures of injector components under a microscope after running ethanol in a system that wasn't designed for it.
Correct
Some fuels will corrode non stainless steel fuel lines
are you saying that using E85 in my 2000 S10 that isnt designed for it will hurt it?
ive always wondered. never tried because i didnt want to find out the hard way.
Thanks,
Branden
4.3
and i wasnt sure what was all done when E85 was used. thats why i never tried it and asked. lol
so trying it would not be a good idea?
ok. ill take your word for it.
im going to be putting a 5.3 in it sometime in the future, will E85 work with that?
You have to edit the stoich AFR and maybe the OLFA/PE tables... you will find that the injectors then need to flow more, so they may have to be upgraded.
thanks Joecar.
We dont know on the year, it'll be from the salvage yard. any certain ones to look for?
Thanks,
Branden
