How to replace an LS1 PCM Flash Chip?
I've accidentally bricked two LS1 PCMs that are licensed to my EFILive V1 cable. The first was toast after playing with electronic throttle tables and the second was a result of a bad calibration file.
I sourced (what I think to be) the correct replacement flash chip, replaced the chip on the board, and I cannot communicate with the PCM using either EFILive or Tech2.
Does the chip need initialized somehow?
Or do the problems go beyond the flash chip?
Maybe I misunderstood this.
Site Admin
After the truck stops, or fails to start, can you check for trouble codes?
If you modify the throttle response too far from stock it can cause the PCM to think something has failed with the throttle system and it goes into a lock-down mode after a period of time (usually between 1 and 30 minutes after starting the engine). When it does that it cannot be reflashed.
If that is the case a specific trouble code will be set, something in the $6000 range. We can recover the PCM here at EFILive but that would require shipping it to Australia which may cost more than replacing the PCM. If you do need to replace the PCM EFILive will provide a free replacement VIN license for the replacement PCM.
FYI, this is the warning that is displayed with the throttle tables in the EFILive software:
WARNING: Alter ETC calibrations at your own risk.
Modifying ETC calibrations too far from stock values can cause the PCM to log a TAC communications fault code and enter reduced power mode.
Extreme modifications may cause the PCM to become permanently disabled.
Paul Didnt this guy brick a pcm and efilive said they would replace a license.
