i need a STOCK FACTORY file for an 08!
i need an UNTOUCHED factory tune file for an 08 6.7 that someone may have backed up. im new to this so im not sure what info i may or may not need to know like PCM types or if the files are adaptable to my truck or not all i know is i have an 08 6.7 cummins 25000 Auto 4x4 short box.
EDIT: OS 11620807
Cal 62350435AZ
When you connect to the scan tool it will show you on the bottom of the screen next to your VIN
Connect the V2 to the truck and your computer. Open the scan tool, turn your key to the on position, click on the green button on the top left of the screen, select CM2100 for your controller, put a check in the box for automatic transmission, then select OK. Once the scan tool fully connects, you will see you VIN on the bottom of the screen. Just to the right of your VIN is the operating system in your ECM right now.
If you post up your current operating system, I'm sure someone on here will be more then happy to give you a clean stock file. I do alot of factory flashing with a factory scan tool. I'm sure I will have yours with the PTO high idle via with the cruise control enabled.
Great info here I will be going through this same headache this weekend.
