Can not read 09 6.7L cummins stock file
i'm trying to tune an 09 6.7L cummins. i can not get the stock file to read on my V2. i've made a few phone calls, no one has had this problem before.... the truck was purchased new, and was recently reflashed by chrysler, so i know it is the stock program in the computer. can anyone help? i get a code: $0311 when i try to read the stock file.
You can find a smarty/H&S, flash that in then immediately return to stock. Then you'll be able to read the stock file.
So here it is in it's entirety...flash with smarty/H&S, return to stock, READ THE FILE, if it HAS a incomplete file, flash a clean OS. This will bypass the boot loader issue and as long as you DO NOT FLASH a incomplete file in, your ECM will live.
