Originally Posted by
GMPX
Ok what about this for a solution.
The problem we have is the front end of the software is not configured for two read options, that was going to be the time consuming task. What about we just include two different scripts? The default is the cal only read that 99% of people will use, then we have another that you would need to manually rename each time the software gets installed that has the full read option?
Eg, it might be called A40_R_FULL.obj, you need to delete the normal cal read script and rename that one to A40_R.obj.
