Originally Posted by
joecar
Yes, save it to replace/overwrite your current file.
The calc pid CALC.CADEG is already pre-defined in the V7 scantool... on the PIDs tab click on the column heading "Parameter" (the last column on the right) to sort on that column, then scroll down until you see CALC.CADEG, on this pid do rightclick->More Info, look at the defined expression, does it match your V8 calc pid for CADEGLBZ...?
If it is different then post a screenshot of how you have it defined in V8, and I'll add it to your V7 calc_pid.txt file.
