Can't full flash? Error $0540
Error $0540 means "incompatible OS"... i.e. you can't change to that OS.
I understand that part but shouldn't I be able to full flash it right over top?
During a cal flash the operating system number of the controller must match (or be a custom version of) the operating system number of the calibration being flashed, otherwise error $0540 will occur.
Error $0540 is also used to indicate a mismatched operating system during a full-flash. A mismatched operating system is one that may not operate correctly with the controller's built-in, boot block software. The following list shows which T43 operating systems are compatible and can be interchanged during a full-flash.
All OS numbers on the same line are interchangeable, if two OS numbers are on different lines then they cannot be interchanged.
24237276,24237685,24239353,24240291,24248859,24243 170
24244551,24249042,24253414,24249179,24251030,24249 833
24247961,24256093
24252573,24254909,24256025,24257135,24256065
24256125,24257238
24261871,24264142,24264923
24265260
24264497,24267577,24270599
24257301
24267571
24268005
The OS changed with the model year on some controllers. With the T43, this relationship is not consistent. Some OS were used for only one year. Some OS were used for two consecutive years. Some OS were used for four consecutive years. With the T43, it is more accurate to reference compatibility with the OS itself, not the corresponding model year(s).
No, nothing like that in T43.
Quick question, which OS is considered the most detailed of these ones?
24249179 should give you everything you need
Thanks Luis
