Known Issues With Current Public Release
Latest updates (released as an auto-update):
- EFILive V7 software: V7.5.9 Build 318 (Updated Dec 29, 2016)
- EFILive V8 software: V8.2.4 Build 312 (Updated Dec 29, 2016)
- Boot Block: V2.07.007 (Feb 07, 2014)
- Firmware: V2.07.109 (Dec 23, 2016) (Updated Dec 29, 2016)
Replaces these previous releases:
- EFILive V7 software: V7.5.9 Build 317 (Updated Dec 23, 2016)
- EFILive V8 software: V8.2.4 Build 311 (Updated Dec 23, 2016)
- Firmware: V2.07.108 (Dec 23, 2016) (Updated Dec 23, 2016)
Updates are described here: What's New
Until the official download page is updated, the latest Dec 29th software update can be downloaded via these two direct links:
Issue 1:
Workaround:
None.
It is a restriction of the *.efi (V7.5 log file format). That restriction will be removed and the TCM PIDs will display their true origin once the V8 scan tool software is available and fully integrated with the V8 tuning tool software.
Issue 2:
When logging DMA PIDs (i.e. PIDs whose names end with "_M" or "_DMA"), if the ignition is switched off for an extended period while data logging but data logging is not terminated, then when the ignition is switched on again the data log automatically continues. However the DMA PIDs may no longer return valid data.
Workaround:
EFILive recommends stopping the data log and restarting the data log when switching off the ignition for extended periods.
Issue 3:
When flashing a Cummins ECM if the reflash fails and an attempt to reflash the controller in 'recovery mode' is made the software will ask for a new license.
Workaround:
Fixed in Dec 29th update.
Issue 4:
Programming device settings on FlashScan and/or AutoCal may fail.
Workaround:
Fixed in Dec 29th update with firmware V2.07.109 and V8.2.4.312.
Issue 5:
Double clicking on a calibration in the list of V7 calibration differences no longer opens the clicked calibration.
Workaround:
None, will be fixed in the next update.
Issue 6:
Some serial wide band controllers' Lambda and AFR values no longer stop at 25 AFR when in free air (or very, very lean condition). Regular AFR/Lambda readings are not affected.
Workaround:
Issue 7:
V8's "test flash" mode for both cal-flash and full-flash does not perform a test erase and flash. It performs a real erase and flash.
Workaround:
DO NOT USE THE TEST FLASH OPTION.
Will be fixed in the next update.
Software updates for V7, V8 and firmware are now available to fix the Cummins recovery issue and Error $0106.
Customers running the December public release can use the Check for updates options. I'll update the software links in this thread tomorrow. Updates Links are on our website.
Thanks for your patience during our holiday break.
Cheers
Cindy
Sent from my iPad using Tapatalk
