February 2021, V8.3.5 Beta 2
NEW BETA RELEASE IS NOW AVAILABLE. PLEASE SEE LATEST BETA SOFTWARE FOR DOWNLOAD LINKS
ATTENTION - BETA SOFTWARE RELEASE
We strongly recommend that you do not install the beta software over the top of your production systems. It is possible that the beta test software may fail and your production system may not be recoverable. lf you conduct a tuning business, please take the necessary precautions to protect your business. EFILive recommends beta testers use a separate FlashScan V3/V2 device (when installing the latest beta firmware) and only install the EFILive beta test software on a separate PC, laptop or virtual machine.
The current public release is available here.
Attention:V7.5 no longer supports installation to Windows XP or Windows Vista. This change is due to SHA1 having been deprecated by digital certificate authorities. More info on SHA1
V7.5 and V8 are now only supported on Windows 7, 8, 8.1 and 10.
WARNING:Due to the new security/encryption option in this release, all tune files saved using this release will no longer be compatible with older versions of the V7 or V8 software. If you distribute tune files to other users (i.e. your customers), the recipients must be:
- using this version or a later version of the V7 and/or V8 software.
- using this version or a later version of the V2 and/or V3 firmware.
Full Release Notes:
Version Numbers:After installing this beta release you should have the following software and firmware versions installed:
- EFILive V7 software: V7.5.34 To view the installed version, select Help->About (in the V7 Scan or Tune software).
- EFILive V8 software: V8.3.5 To view the installed version, select Help->About (in the V8 Scan and Tune software).
- FlashScan/AutoCal V3 Firmware: V3.00.059 (Feb 22, 2020).
- FlashScan/AutoCal V2 Firmware: V2.07.169 (Feb 22, 2020).
Download here:
Known Issues:Issue #1:
Custom operating system (COS) upgrades are not being applied completely.
If you have applied a COS upgrade to any tune file using the V8 beta software, please delete the resulting tune file(s). Those partially upgraded tune files will contain only a partial COS upgrade which will not work and may cause problems if flashed into a vehicle.
Workaround:
Use the V7 software to apply COS upgrades.
Will be fixed in the next beta update which will be posted as soon as the fault is rectified.
Issue #2:
Saving an E98 *.coz file creates the file with some data missing. That will cause a $06FF (checksum) error if that *.coz file is flashed into an E98 controller.
Workaround:
None.
Regards,
The EFILive Team
Some of us are having a problem with this.....
Quote:
Originally Posted by
Blacky
I know you like V7, but it is time to take it out the back and shoot it :)
Some of us are having a problem with this..... :bash:
At least I know I'm not alone....
Chuck CoW
