has anybody used the 96 lbs smartfire injectors? what data would they need? (its for an ls7.)
https://smartfireinjectors.myshopify.com/
never heard of them. but you need to request data from them before buying.
they dont have any data, they tell you to "custom tune" or get dautschwerks from them (that as far as i can see dont provide "proper" data either). i thought these being 25% of the id (or whatever) price, somebody might have figured out how to use them.
Deatschwerks has good data on their website.
I use Deatschwerks and Fuel Injector Connection for all my customers cars/trucks. They make it easy with good data.
Without data, a "custom tune" is difficult to dial in all conditions.
iv seen other injectors in that price range. how come you have to dish out $1000 every time you need injectors, when with a bit of effort these could surely be made to function? well, maybe not. if it were so simple, the vendors would surely do it themselves. where is the problem? consistency when they just use a pcb drill instead of a sinker?
If you spend enough time with them and figure out what settings they need to work right.
but FIC has some 80# for $580 with good data.
id rather spend a little money for good data vs burning my time trying to figure out injector data.
They don't have data because they're cheap crappy chinese injectors and they all flow differently. Read reviews on other sites and you'll see people with dead injectors out of the box, injectors that don't inject at idle (some of their injectors have huge deadtimes and just don't work on small pulses), and injectors that fail after a relatively short time. There's a reason that cheap injectors are cheap.
Nobody ever complains about the price of their new cam or the price of their new supercharger..... but shit, look at the price of those injectors!!!
I was kinda worried about the same thing, there are a lot of china copies out there. Man, I've just about burned up my 2 injector machines testing these trying to match up sets. While you can match sets for WOT, the lower pulse width differences can't be fixed or even matched so they are saleable. Trash :(
Yep. I learned that a long time ago.. buy from a reputable company and get good stuff.
thanks for the feedback.
were kind of back to the "china thing": if you buy stuff on ebay its crap (and it often is but more often not). so everybody thinks "All of our TRE Fuel Injectors are manufactured according to strict guidelines in order to maintain ISO 9002 and ISO/TS 16949 quality system certificationsas" and their "asna testing" is b.s.? then there is their 1 year warranty as well. sure, i also have been messing with a motec analysing injectors for many hours and its not worth it. what i meant is why doesnt somebody do this commercially in large quantities? if you get a set of 8 for $230 incl. shipping there surely would be a margin for profit.
(as to "pay your money and get the best": i guess we wouldnt be here tuning. we would be driving a ferrari or a lamborghini truck. people often decide on a cam because of a $50 price difference while spending 20 hours+ on the install. btw, rockauto has e.g. ls7 injectors for $30 and i doubt they dont work.)
has anybody out there tried this vendor?
https://treperformance.com/i-2389988...jectors-8.html
Hiya,
Well, siemens deka's aren't very good right out of the box FROM THEM, of course they work "good enough" since I have seen literally thousands and thousands put to use. The 80lb is ~92lb at 4 bar which is probably what the treperformance is selling. They are a single stream injector. The whole injector variance issue is very time consuming and unless that it what you do 100% of the time, it is not cost effective :( If I have to order injectors I usually use Deats https://deatschwerks.com/ because when they arrive, they are good and match my flow benches. They mainly use good bosch injectors and grind off the part number, then flow match to the last couple percent. I would bet other reputable companies do the same.
except that they go up to 700cc (750? out of memory) and then you have to drill them.
how hard is it to get that dw data into efilive?
Why would you drill them?
Data is copy/paste from DW.
I use these on several turbo trucks and their data has been spot on.
DW 35U-00-0072-8
has anybody used this vendor?
https://aeroflowperformance.com/af49...-fuel-injector
"Why would you drill them?": my understanding is bosch injectors dont come in larger sizes. the aftermarket vendors enlarge the hole(s) by edm, broaching, drilling. i have no yet heard of anybody using a laser like bosch does.
Are you in Australia?
im in switzerland. how would that matter?
(at this point im looking to purchase 24 injectors/3 sets so it makes a difference if i pay $1100 for ids or $400 for this. if i take on my friends cars it will make an even larger difference.)
Hiya Dian, it appears you have been after this for a while. What exactly are you looking for? I don't generally become a seller but I can supply whatever you would like, and flow tested.
e.g. 8 injectors to go into a blown ls7 on gas/petrol. 850-1050cc*. has to pass emissions (→idle quality). do you test dynamically? actually i have no idea what an aceptable divergence would be at lets say at 1.5 ms. i see injectors matched to 1% at full flow having 4% in "dynamic" testing, no idea if there even is a standard for it. so i figure there might be around 10% divergence at idle? anyway, something proven to work. (deka 60 had some problems on a ls1, but i made them work and they pass the test.)
*@3 bar
in the meantime i got "data" from aeroflow. they give you:
- flow at idle (is that the knee?)
- flow at 3 and 4 bar
- "dead times" vs. volts for 3, 4 and 5 bar (no idea if this is maybe with half of the opening ramp added?)
do you think this can be converted to efilive with some success?
