I was thinking about getting one of these and was wondering if anyone could give me some info/review as to how they like/dislike it.
haven't used a fast wb, but I am running a dual lc1 config. <gump> I like it alot
I don't think there are preprogrammed pids or this setup....? I guess cause it's too new. Anyone else tried this setup? It looks pretty cool: http://www.fuelairspark.com/Products...rFuelMeter.asp
Ive been using the Fast for a while now.The only thing I dislike is having to go thru a couple of key strokes to get the analogue output working each time.
Most other widebands I've used start up once power is supplied.
Thou you do have the advantage if lap top not connected a small screen to look/monitor AFR whether individually or an average of both.
Here's the pid set up I'm using:
# Add slot definitions here
# See sae_generic.txt for more information on "SLOT" formats
#Units Low High Fmt Expression
*CLC-00-991
"AFR" 10.0 20.0 .2 "({CALC.AFR_FAST1.AFR}+{CALC.AFR_FAST2.AFR})/2"
*CLC-00-990
factor 0.0 2.0 .1 "{CALC.Fast_AFR_AVG_B1&B2}/{GM.AFR}"
# Fast WBO2
*CLC-00-985
V 0.0 5.0 .1 "{EXT.AD1}"
AFR 10.0 20.0 .1 "{EXT.AD1}*2.78+9.6"
*CLC-00-984
factor 0.0 2.0 .1 "{CALC.AFR_FAST1.AFR}/{GM.AFR}"
*CLC-00-983
V 0.0 5.0 .1 "{EXT.AD2}"
AFR 10.0 20.0 .1 "{EXT.AD2}*2.78+9.6"
*CLC-00-982
factor 0.0 2.0 .1 "{CALC.AFR_FAST2.AFR}/{GM.AFR}"
*PRN - Parameter Reference Numbers
# See sae_generic.txt for more information on the *PRN section
#Code PRN SLOT Units System Description
CALC.Fast_AFR_AVG_B1&B2 F602 CLC-00-991 "AFR,V" O2-Wide "Average Fast1 & Fast2"
CALC.BEN_AVG_FASTB1&B2 F603 CLC-00-990 factor O2-Wide "Base Efficiency Numerator(AVG) - Fast"
CALC.AFR_FAST1 F618 CLC-00-985 "AFR,V" O2-Wide "Wide Band AFR 1 - Fast"
CALC.BEN_FAST1 F619 CLC-00-984 factor O2-Wide "Base Efficiency Numerator 1 - Fast"
CALC.AFR_FAST2 F61A CLC-00-983 "AFR,V" O2-Wide "Wide Band AFR 2 - Fast"
CALC.BEN_FAST2 F61B CLC-00-982 factor O2-Wide "Base Efficiency Numerator 2 - Fast"
Ive just ordered one a few days ago, liked how it takes both sensors and averages them out.
Not sure when its due to arrive but im sure ill have it in the car the same day!
Welcome to the Forum Rosco
Thanks!Quote:
Originally Posted by TAQuickness
Efilive has been so useful to me so far, ive just ordered a load of new parts for my LS1 so will be getting lots more use out of it soon!
Rosco,Quote:
Originally Posted by Rosco
Welcome. :cheers: Let us know how it all goes.
Joe
Yes please post more feedback on this unit.:)
Hope you got it at a good price.I bought mine here only $50 dearer than two LC1's.
http://www.compperformancegroupstore...?Store_Code=PH
Look under "Tuning tools.":cheers:
Got mine off ebay for $439 plus $35 shipping to the UK :) kinda limited where I can buy parts as availability in the UK is limited and outside the UK they have to take paypal.Quote:
Originally Posted by VT LS1 NZ
Will let you all know on how its going, cant wait for the parts to start arriving!
Well the FAST dual wideband arrived over the holidays and I managed to get it all installed and setup.
The display box is a little larger than I was expecting and have to find a suitable location for it as yet but it is easy to use and can output an average of both O2 sensors.
It gives the same output as the LM1 so you can use the settings for that in EFILive.
The instructions for AutoVE were nice and easy to use and have got me well on the way to getting the car where she needs to be :)
Just waiting on the rest of my parts to start arriving so I can get on with the work!
When I put my new cam in is there anything that I need to change or will I be able to use AutoVE to tune for the cam?
AutoVE will get you going for the new cam. Depending on what you got, you will need to look into your spark and timing tables a bit too.
VT LS1 NZ, thanks for the post, i have tried this, and it works though the afr on the FAST compared to the laptop is vastly different, i have modyfied the pid and got it much closer, however its not correct, the fast meter says a 0-4.096 and v*2.78+9.6 i had to change to v*1.97+10 to get the closer afr.
any ideas to why this is happening?
regards
Agro
My wide band reads correctly.Quote:
Originally Posted by AGRO
When you get your wideband and you go thru the set up menu set it up to use outputs.Also you will find when you go thru the menu there is a cal formula there for you to use.
yeah that is all down pat, though the voltage output spikes alot, thats what seems to be the problem, i cant get this to work properly, its becoming very frustrating.Quote:
