Well for starters, i stopped using EFILIVE as it clearly destroyed my PCM, i had tooooo many issues after the january 8th and later revisions of the software, it seemed to not like my os revision of the pcm, and i know i am NOT the only with this issue
Anyhow the way i have my efans setup is like this,
i used a flexalite controller with a/c bypass number 33054 Variable Speed Control Module
if you do not have issues with your efilive and pcm you will need to change g1021 to 18v or more so it disables the clucth fan diagnostics
you can check on my photobucket for more pics of installation, ALSO i would suggest to trim the efan so it sits flush on the rad, having the upper and lower lip as is, would allow hot air from the engine bay to be sucked from the sides and not through the rad, affecting the performance of the efan
http://s219.photobucket.com/albums/c...efan/?start=20
http://s219.photobucket.com/albums/c...e-fan%20parts/
