Flash scan box has alternating orange led's nothing happens. the thing is dead?!?!?
were you updating the V2 ?
any more info you can supply eg unit is new / been working ok just stoped
Geoff
It's been working fine. my sisters little kid was over. she might have played with the box. but there's nothing you can even do to the box is there?
I would plug the unit in & see if you can read it and try a reflash of the V2
The two alternating flashing orange LEDs indicate the firmware has been deleted or changed.
To reprogram the firmware run the program on the Start menu:
Start->All Programs->EFILive V7.5->Update FlashScan Firmware.
Click on the [Status] button and make sure the Bootblock version is 2.4.10
Then click on the [...] button and locate the firmware file:
\Program Files\EFILive\V7.5\FSProg_V2_4_70.ffw
Click the [Program] Button to reprogram the firmware. It should take about 30 seconds. The status bar may freeze during the reflash, but once the reflash is done successfully, FlashScan will Automatically reboot.
If it happens again, or if the reporgamming does not fix the problem, please take note of the circumstances under which it happened and let me know at [email protected] (include a link to this thread so I can correlate your email to this thread.)
e-mail sent :frown:Quote:
Originally Posted by Blacky
Currently I have the 2.5.04 bootblock with 2.5.15 firmware.
Now, when I go to deadpoll to convert back to 2.4.70, it says it cannot communicate because its not in deadpoll..??? I have the 2-orange lights flashing, so I know it is in deadpoll. What can I do to fix this..?
Ah I see, you've already upgraded to the BB Logging beta firmware. In that case you need to use the EFILive_Explorer.exe program to reprogram your firmware.Quote:
Originally Posted by 4DRSS
You will also need to use the firmware that came with the BB Logging beta software instead of the file I mentioned in my previous post.
What about me, my shit is still broke?!?!?!? Where is this EFILive_Explorer.exe?
problem fixed! looks like the bootblock got upgraded without me knowing it?!?! Damn kids! anyways just loaded the new firmware and it works just fine.
Ok thanks..Quote:
Next question, why are the firmwares different as far as the file extentions..? EX: .efw / .ffw
With the EFILive_Explorer.exe you cannot load a .ffw firmware file in order to revert back to the previous 2.4.70...?
Thanks-
Hmm, yes there is an option in FlashScan to upgrade the bootblock. Now that you've upgraded I recommend keeping a close eye on this forum to get the beta updates. A new update is due out in the next day or two.Quote:
Originally Posted by bballer182
http://forum.efilive.com/forumdisplay.php?f=69
Sorry, I missed this question, just saw it again now...
The upgrade from V2.4.x firmware to V2.5.x firmware requires a new boot block in the FlashScan memory. The boot block is the underlying software that controls the FlashScan hardware. Sort of like the BIOS in your PC.
The boot block is not very "smart", it just has a bunch of low level hardware "driver" functions. The firmware invokes boot block functions to manipulate the FlashScan hardware - to reprogram the flash memory, to control the LED's, the keypad and the USB coms etc.
The boot block is not designed to be updated regularly since the underlying hardware will never change. However, we needed to make a change when going from V2.4 to V2.5. The change involved some very low level hardware instructions.
Once the boot block has been upgraded to V2.5 it is no longer compatible with the V2.4 firmware. That means you can ONLY run V2.5 firmware once the boot block has been upgraded to V2.5.
We deliberately chose to not allow downgrading to V2.4 because it would allow too many combinations/permutations of boot block and firmware versions to support effectively.
