BB Logging beta update: April 07, 2008
This BBL update has been removed due to a potential failure of FlashScan units.
DO NOT UPGRADE YOUR FLASHSCAN UNIT TO BOOT BLOCK VERSION V2.05.06
PLEASE NOTE!!!!!!!!!!! When you download this zip and go to install the firmware, YOU MUST INSTALL THE BOOT BLOCK UPDATE V2.05.06(0407) FIRST on your V2! Failure to do so will make your V2 unit not talk to EFILive Hapi and will not work.. Then after you install the boot block update you can continue to install the Firmware. But only after the boot block update.
ALSO Do not do full flashing of a new custom os for the pcms/ecms. There is a known bug that wont allow the computer to be seen while the cal segment is empty. Fix will be soon.
Download here: Download is no longer available
This download includes and supercedes the previous (March 26) download.
Please read the Readme_First.pdf file included in the zip file.
It contains important, updated information about how to upgrade the boot block in your FlashScan and/or AutoCal devices.
Make sure you update your FlashScan (and/or AutoCal) firmware and boot block using the latest firmware file(s) in the EFILive_Hapi folder.
Please read the first posts in the March 20 and March 26 releases so that you are aware of the previous versions' pre-requisites.
http://forum.efilive.com/showthread.php?t=7643
http://forum.efilive.com/showthread.php?t=7566
1 Attachment(s)
Captured a DTC with V2 BBL...
My PCM emitted DTC P0420...
I read it ok with V2 BBL, saved all diagnotics to file (see attached)... FF1 seems to be a copy of FF0.
The FF's in the attached file contain a line that says "$119E=$8B".
Then I went to clear DTC's and V2 said "Error $0281"...
the MIL went out at the same time...
I went to reread the DTC's but they were cleared, so V2 must have cleared the DTC.
Edit: I corrected my typos.
