Originally Posted by
mr.prick
i have tried all the easy fixes i can think of,
the windows, stereo and lights work but the fuel pump is locked out.
can someone confirm that flashscan will not be able to
connect/retrieve ECU info (VIN and tune) if the BCM is DOA.
i can`t down/upload or read the VIN with the stock ECU.
the RR connects, reads writes but will not update which is
a mute point because when i did get the car to idle it only did so
for maybe a minute then when kaput.
the fact that the RR can do everything but update seems to
prove it is vehicle (BCU?) related.
