I'm running into some ghosts with the newest release. I have also noticed at least one mis-labeled parameter. I datalogged a run and I will post some results in a bit.
Thanks for pointing it out, when you stare at those maps all day developing it's pretty easy to miss that sort of thing.
{B4541} "Full Throttle Mode, TPS Enable" should be Disable since {B4540} is Enable.
Hi Nick,
Found the fault and fixed it.
Thanks for all the work you did tracking down and sending the trace files.
The problem was the V8 software was not identifying the DSP5 tune files correctly when they were being opened and it was flashing part stock data and part DSP5 data - causing the problems you experienced.
I expect to have an update (Release Candidate 8) available tonight or tomorrow.
Thanks Paul. Much appreciated
Yeah, I had to have a Bosch ECM on the bench again today :yucky:
