I haven't had much luck finding, nor making a PID that reads out MPG like the LS1 CALC.MPG does. Again, this is on a E38 controller.
Can anyone point me in the right direction?
Sam, post your calc_pids.txt file.
Here you go :)
BTW: you need to add at least 2 blank lines at the end.
Which of the referenced pids is not available for E38...? Is it GM.IBPW1...?Code:*CLC-00-020
MPG 0.0 100.0 0.2 "{SAE.VSS.mph} / ({GM.INJFLOW.lbpm} * {GM.IBPW1} * {SAE.RPM} * 4 / 6250)"
Thanks for the tip on the calc.pid.txt Joe!
GM.INJFLOW.lbpm is invalid for some reason. Tried on 2 different computers just in case. GM.IBPW1 works perfect just like the LS1 controller.
