2 Attachment(s)
Known issues with Feb 14, 2015 release of the EFILive software and firmware.
Currently known issues and possible workarounds for the Feb 14, 2015 release of the EFILive Software and Firmware
- Software: V7.5.7.278
- Software: V8.2.2.272
- FlashScan/AutoCal firmware: V2.07.79
Issue 1:
Workaround:
None. It is a restriction of the *.efi (V7.5 log file format). That restriction will be removed and the TCM PIDs will display their true origin once the V8 scan tool software is available.
Issue 2:
Attempting to use V7.7 pass-thru logging with CMD/CME controllers results in the error:
Code:
Error code: ERR_CONFIG/92
C:\Program Files (x86)\EFILive\V7.5\Configuration\cummins_enhanced.prn(919): Slot UNM-08-5002 with units Amps not found.
Workaround:
Download the attached cummins_enahnced.zip file and unzip it into the folder \Program Files (x86)\EFILive\V7.5\Configuration. Overwrite the existing cummins_enhanced.prn file. You will need Windows Administrator privilege to overwrite that file.
Issue 3:
Attempting to load some cummins CSP5 tune files may result in the error:
Code:
EFILive cannot determine some OS specific data. Most likely because the data is from a controller that has not yet been added to the EFILive software.
Or when starting the SCan Tool, the error:
Code:
C:\Program Files (x86)\EFILive\V7.5\Configuration\cummins_enhanced.prn(968): Units may not be specified for slot: SED-08-5010.
Workaround:
Issue 4:
Date-time sorting does not correctly handle US or Euro date formats for date-time values between 12:00:00 a.m and 12:59:59 a.m. For sorting purposes those date-times are incorrectly treated as p.m. which means they are sorted after 11:59:59 p.m. This problem is a display issue and only affects the order in which scan/tune files are displayed in lists, such as on the main EFILive V8 window.
Workaround:
If you need the dates to be sorted correctly, set the "Display Formats" for "Dates:" to "Default" in the Edit->Property->General->Locale settings. Will be fixed in the next update.
Issue 5:
Can't read Cummins CMB (06-07) controllers. Returns error $0322.
Workaround:
Download the attached "CMB_Update_For_0322_Error.zip" file and unzip the contents into the folder \Program Files (x86)\EFILive\V8\Config. Overwrite the existing two CMB_R.obj and CMB_F.obj files. You will need Windows Administrator privilege to overwrite those files.
