I just finished csp file flashed it into truck with no issues. Went on test drive now the speedometer doesn't work and the abs light is on. Has anyone ever ran into this issue.
Are you positive you flashed the correct file for your truck?Did you change anything else?
Sent from my Samsung Galaxy Note 4 via Tapatalk Pro
Yes sir os matched both 07 5.9 files. I did not use the stock file from the truck though because it was previously flashed with a smarty.
I haven't done anything to it but tune it.
I fixed it. I updated the vin in the pcm and it fixed the problem.
