Injector timming on lml
When changing injector timming on main injection do I need to change all of it to the same amount such as every table under piliot injection #1 there is 10 plus tables all with different modes. Ive loged it and cant figure out when different modes come on or can you just edit one mode and somehow lock in in the one mode?
--Thanks for the help
The engine will use different maps based on altitude and egr status among other things. Only way to tell is by logging.
If you are new to this you might want to leave those alone. The motor will rattle a lot if you jack them up too much, because they all look really low, If you want, copy and paste the high altitude map that has the most timing in it on all your low altitude maps.
