Can any one point into a direction that solve a safe mode issue on 2004 Monaro CV8 vehicle. The vehicle will randomly go into safe mode and we haven't been able to find the cause codeP2125 logs but I don't believe he throttle peddle is the issue.
try a different Thottle Postion Sensor
Don't have one spare to try. However I have managed to get a hold of Holden power train specialist, Holden don't have a part replacement currently on hand but the unit was manufactured in England, hoping they can help with the peddle sensor issue.
Attachment 23010Attachment 23009
I appreciate your reply, anychance that you could take a look at the photos at let know your view on the circuit board
Can you check continuity across the solder joints.
Look at each one thru a magnifer/lupe, see if there are any cracks in the solder joints... you may have to reflow the solder.
The "wiped" areas of the traces: can you clean these (rub very lightly with brass wool, just clean them, do not take metal off).
