Any Update???? Like everybody else have to tune and scan a LS1, can read and write with V8 and tune with V7, but unable to scan, simply wont connect.
Update available here:
http://forum.efilive.com/showthread....126#post133126
I will test it in few hrs, I have some customers today.
Worse on VX LS1
Scan does not connect at all now (previously connected after 1min and then worked fine)
Read hangs on detect TCM and then fails about 4 min later after trying to initialise the ECM?PCM
Closing this thread as new posts should be made in the new thread (http://forum.efilive.com/showthread....126#post133126). Issues should be logged in the EFILive Helpdesk system (as noted) at http://support.efilive.com/. See this post for more info (http://forum.efilive.com/showthread....643#post130643)
