EFI not reading AFR correctly
Since EFI is reading a different AFR than my LM1 do I need to change the values in the sae_generic.txt from what I have which is this:
*CLC-00-928
V 0.0 5.0 .1 "{EXT.AD1}"
AFR 10.0 30.0 .1 "{EXT.AD1}*10"
*CLC-00-929
factor 0.0 2.0 .1 "{CALC.AFR_LM11.AFR}/{GM.AFR}"
*CLC-00-930
V 0.0 5.0 .1 "{EXT.AD2}"
AFR 10.0 30.0 .1 "{EXT.AD2}*10"
*CLC-00-931
factor 0.0 2.0 .1 "{CALC.AFR_LM12.AFR}/{GM.AFR}"
To this which I found here during a search http://forum.efilive.com/showthread....highlight=Lm-1
Which is this:
*CLC-00-928
AFR 10.0 20.0 .1 "({EXT.AD1}*1.9936)+ 9.9832"
*CLC-00-929
*CLC-00-930
AFR 10.0 20.0 .1 "({EXT.AD2}*1.9936)+ 9.9832
*CLC-00-931
__________________
Any help is greatly apprecaited.
Thanks,
Bill
