1 Attachment(s)
Public Release Update June 06, 2011
The EFILive V7.5 and V8 software is available for download.
This release includes the 5.9 Cummins Scanning and Tuning support.
Read more about the Cummins features here:
http://forum.efilive.com/showthread....Public-Release
Download here:
http://www.efilive.com/index.php?opt...=48&Itemid=133
Auto Update:
The Auto Update option will be activated on Monday June 13 US time. Until then you need to download and install the software manually.
Once the Auto Update option is activated your system will see it as a new update and download and install it, regardless of whether you have downloaded and installed this release manually or not.
Known Issues:
Issue #1Some PC's/laptops will freeze when attempting to start the V7.5 Tuning Tool software while FlashScan and/or AutoCal is connected. The problem appears to be an incompatibility between the newest USB drivers and some customer's PC/laptop configurations.
Please revert back to the older USB drivers. To do that, download the attached zip file, unzip it and run the EFILive_USBManager.exe program. To install the older USB drivers, click on the [Install USB V2.02.04] button.
Issue #2There is a bug in the latest V8 software that prevents the BBX [Program] button from updating the *.obj and *.bix files from being correctly identified as needing to be updated. That means after the user has clicked on the [Program] button the *.obj and *.bix files will not have been updated to the latest version.
That will usually result in error $050B "Script file not supported by current firmware version".
The workaround is to have the user to select the "Program All Required Data" from the [Program] button's drop down list.
Reporting Issues:
If you discover any serious problems/faults, please create a support case here:
http://support.efilive.com/
If you discover simple/trivial issues, please make a note of them in this thread.
What's new in this update:
V7.5.7 Build 165 (June 08, 2011)
- Fixed calculated PIDs expression compiler/evaluator not compiling or evaluating the iff() function correctly.
- Command line switch "/l" now logs expression parser output (algebraic form) and compiler output (post fix form) to aid expression verification.
- Installer now automatically updates the cal_summary.txt file with the latest Cummins calibration summary options.
- Installer now forces overwriting of all non-user modifiable installation files.
- Added new Cummins OS 11501001
- Added VATS (vehicle anti-theft) disable for Cummins controllers.
- Fixed "Access Violation" error when more than 128 BBx config files were selected to be programmed into FlashScan or AutoCal.
- Fixed *.cax files not being loaded by the V7.5 tune software.
V8.2.1 Build 156 (June 08, 2011)
- All *.htx trace files now log the currently installed USB driver and library versions.
- EFILive Control Panel now displays the USB driver and library version numbers in the "About" screen.
- Added option to automatically delete *.htx trace files older than a user defined number of days.
- Disabled buttons and menus in BBx setup window while programming configuration files to FlashScan/AutoCal.
FlashScan/AutoCal Firmware V2.07.12 (Jun 06, 2011)
- Added Cummins OS compatibility matrix to pre-flash validation checks.
