As the title reads? Is it just a case of copying the file to VZ in the explorer? whats the destination folder , I tried Tune/read...
thanks
thanks
Hi Gelf,
Almost... in the tunetool, open your .tun file and save as .ctd, this is what you copy to V2 using EE.
More complete info:
Download the latest V7/V8 software from here and flash firmware 2.6.36 into V2.
Using S&T:
- Device Settings: set these appropriately and program into V2;
- Black Box settings: set both Scan Settings and Tune Settings (you have to specify your PCM type), and program into V2.
Then:
- in tunetool open .tun file, and save as .ctd;
- in EE, goto Data Files tab, click Home; in upper pane browse to your .ctd file and copy it to the lower pane;
- take V2 to vehicle, and flash to PCM.
Tutorial on setting up V2 for BBF(BBR/BBW): showthread.php?14056-Guide-How-to-flash-the-ECM-with-handheld-V2-BB
