After having zero trouble on 06/07/08's an 09 has stopped the show. :doh2:
Anyone managed to disable VATS on an 09 E38 12628990 Corvette OS?
I disabled VATS via the patch as usual and full flashed but the engine wont fire. Coils turn on and injectors pulse once with key in crank position and then thats it. Subsequent starts there is no injector pulse unless the ECM is powered right off.
Similar behavior if an 08 E38 that has NO VATS disable applied.
Plug an 08 back in or anything else less than 09 and starts right up.
Has VATS been proven on this OS for 09?
Thanks anyone :).
