If you can share the details of the source for resister and capacitor you use id be grateful, i had a look online but not sure exactly what to order?
Hi Joe, Ive got to re order the caps as i have lost them, there out of stock til end of the year thou, can i use an electrolytic capacitor instead, whats the difference in this application?
Ive got two LC-1's, one has the green wire, the other is without, so i want to wire them both the same using the cap and resister on the white wire.
You could also use tantalum caps.
You could use electrolytic caps but they have a bigger size (won't tuck so nicely into wire harness).
