1 Attachment(s)
Data Logging Issue
Hey guys this is my first post here. I have been messing around with tuning here and there and have read much of this forum. A lot of good info here. (thanks to all!)
The issue I am having is when I try running the data log and look at it in the tune file at the same time for the Main Injection Duration table only. The Purple box moves along the CMD fuel, but it stays in the max fuel pressure column. I've uploaded a screen shot to show that when I map it in the scan tool, everything displays correctly. This does not happen with any other table.
Another quick question is me being curious about why every tune I've seen drops timing in the upper left portion of the Main Timing Map. I read that it's there for fuel economy and response. Does it make the throttle too sensitive at low rpm and low throttle?
I've got similar issues, hope to hear a fix for it.
