Just getting started with my tune. Hooked up LC-1 with display and it reads fine (output 1 is connected to FlashScan V1). Scantool shows proper voltage fluctuations for EXT.AD1 when monitoring, shouldn't WO2AFR1 be changing too? Thanks.
You want {CALC.AFR_LC11} for AD1 & LC-1
EXT.WO2AFR1 is for serial WBO2 connection.
{CALC.AFR_LC11} is for the factory programed output of the LC-1's analog#2 (brown wire)
Read this post for more information on analog output settings.
+1...
EXT.WO2AFR1/2 are for serial wideband connection (FlashScan V2 only).
EXT.AD1/2 are for analog wideband connection (V1 and V2).
My bad. Thanks guys. Must read before posting....
