2 Attachment(s)
Will not idle after restart
No sign of LTFT or STFT here is a log and the tune used on the log, no mater what i change it seems to act the same, flash cranks and starts idles fine a/f 13.5:1 turn off crank starts for a few seconds a/f is 18:1. If i turn the key of for about 1 min it will start and act just fine, if you try to restart right away it does the same things that is in the log i might need to see some different pids but not sure what is going on for which ones to look at. I am lost something with the ecm or engine is all i can figure now take a look let me know what you all think.Attachment 11391
Attachment 11392
