went to bbl my lml and gave me error 0185 i deleted all pids except for e86a and ibalso reconfig file system now it says something about config files required. whats the deal? i have latest updates
Nobody? I haven't used efilive in awhile so kind of confused when you all talk about config files, ppm, options text etc. can you help I would like to do some logging before I mod the truck, while I am on my 3000 mile road trip
From the error codes pdf:
Quote:
$0185 F_ERR_NOTFOUND A file or folder was not found. You may need to copy a required file to
FlashScan or AutoCal using
EFILive_Explorer.
Or you may need to format the target file
system, see description for error $0182
above
ok got the error to go away and when i hook to truck it lets me pick the pid for the ecm but its blank. when i go into v8 and open scan tab it shows pids so i dont know why it shows there but not when i hook up BBL to truck
There are 2 ways to data log using V8 software, based on the steps you've outlined above using V8 software we have no idea knowing which option you used.
1. Pass-thru logging- To access this, connect FlashScan V2 to your vehicle and PC, then launch V8 Scan and Tune software. Navigate to [F2: Scan], select your ECM and PID's.
2. BBL - To setup standalone logging , connect FlashScan V2 to your PC, then launch the V8 Scan and Tune software. Navigate to [F5: BBX] -> [F2: Scan]. Select you controller and PID's and PROGRAM your FlashScan device so it receives the correct configuration files to all standalone logging. This knowledgebase article should assist you in configuring your FlashScan for black box logging (BBL) https://support.efilive.com/kb_artic...6659-YAHB-3781
Cheers
Cindy
Ok just so i do it right, I add the pids i want and just hit save? When do you use the program/config button?
Save writes to a file on your PC.
Program writes it to your V2... you have to do this.
Got it now just need to figure how to change the units in my bBL
