Seeking Base Tune - 03Z with LS2 402 / V3Ti
My LS6 ate a lifter and cracked the block, so I had an LS2 402 built which I am picking up this weekend.
This is a 58x build, so I believe I will need to use the LPE signal conversion box for cam and crank position sensors. I'll be mounting the knock sensors (LS1 style) to the block exterior.
It's a simple street build.
402 @ ~10.5:1
Arun Jam Cam
LS7 TB w/ harness adapter
FAST 92
(not sure which MAP sensor is on this car currently)
Siemens Deka #60 injectors
no MAF
and a V3Ti w/ 3.8" pulley for now
Any help getting it started would be appreciated.
