In the Scan tool-MAPS I click on {4307} Des Airflow-IG AC OFF (RAFIG-RTACS) Metric and nothing happens.................Paul
you will need to edit the cal link.txt in My Documents\EFILive\V7.5\User Configuration
(i also copy the cal link.txt in C:\Program Files\EFILive\V7.5\Configuration)
you will need to add this:
;Desired Airflow
B4307.ROW=SAE.ECT
B4307.RRR=+,CALC.RAFIG,CALC.RAFPN,CALC.RAFACIG,CALC.RAFACPN
only select one of the PIDS in red to be used at a time.
be warned, you will need to set the update value to a high value.
changing this table to quickly in real time will probably stall the car.
the equation in blue is also important,
it determines how logged data is applied. :)
For some reason cal link.text is not there.I have cal_favorites,cal_setup,cal_summary and calc_pids.If I go to C:\Program Files\EFILive\V7.5\Configuration its there,But it say's cal_link.Is that it?I'm I missing something?And exactly where would I put the info you gave me?Would it go in between B4107 & B4310 under default ROW/COL layout for most LS1 operating systems:unsure::unsure:?......................Paul
1) yes, that is the file, cal_link.txt in the Program Files folder as you have indicated. To make finding it easy, I right clicked and linked mine to the desktop. I did that for options.txt, cal_link.txt and cal_pids.txt.
Note: options.txt, sets up your flashcan for black box logging
cal_link.txt tells the efilive tune.exe how to update via road runner
cal_pids.txt has your calculated pids, often used in cal_link.txt and scanning software.
2) Look for this in CAL_LINK.TXT:
;Desired Airflow
B4307.ROW=SAE.ECT
When found, add this:
B4307.RRR=+,CALC.RAFIG,CALC.RAFPN,CALC.RAFACIG,CAL C.RAFACPN
just overwrite that with what i posted.
remember not to get to crazy with RAFIG and RTACS.
